ash1ey
Message 11 of 23
Re: Extremely slow download speeds
Sure I will post another in about an hour or so.
ash1ey
Message 12 of 23
This is an updated test I did a few mins ago.
Please visit FAQ section if you are unable To understand the test results.
Test1 comprises of two tests
1. Best Effort Test:  -provides background information.
 Download  Speed
 91 Kbps
0 Kbps2000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 91 Kbps
 For your connection, the acceptable range of speeds is 800-2000 Kbps.
 Additional Information:
 Your DSL Connection Rate :2390 Kbps(DOWN-STREAM), 940 Kbps(UP-STREAM)
 IP Profile for your line is - 2107 Kbps
2. Upstream Test:  -provides background information.
 Upload Speed
 722 Kbps
0 Kbps940 Kbps
>Upload speed achieved during the test was - 722 Kbps
 Upstream Rate IP profile on your line is - 940 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
mark_collacott
Message 13 of 23
John,
How can he when if fails. I have the same problem, although I live in Exeter. I am banging my head against the wall with BT customer service, and everytime I have tried the BT speed tester it fails as well probably because the connection speed is so slow, it times out!!
ash1ey
Message 14 of 23
Yea sounds like I am having same problems as you Mark (i just finished reading your post). Strangely after emailing the mods on the forum and then noticing in my emails I have an engineer booked for tomo, things have picked up slowly today. I can load webpages but am still experiencing bad lag when playing games etc.
mark_collacott
Message 15 of 23
My speed is staying the same. I have just about been able to use this forum, but it is soooo slow loading the pages. Most sites, will take at least a minute to load, if at all.... and those that do, don't load completely. Lots of blank frames etc.
ash1ey
Message 16 of 23
Right now as I've said web pages are ok, just tried to watch something on 4oD and gave up after about 10 secs after it was obvious the stream was gonna be poor (starting and stopping alot).
Almost went out and brought a dongle today just to have some sort of internet access that isnt as bad as dial-up.
If the issue isnt resolved in the next few days I will  be canceling the contract due to poor quality of service.
ash1ey
Message 17 of 23
So i was just about to try a different router to make sure its not the hub but before i did I gave the hub one more restart to test the connect.
Both the BT Beta tester and speedtest.net are showing a 1.7mb connection!
I wont hold my breath on how long it will last tho. Keeping my fingers crossed!
Message 18 of 23
mark_collacott
He had already posted the bt speedtest results before you posted your comment as youcan now see the posters speed has started to improve and he as an engineer visit booked
ash1ey
Message 19 of 23
Knew it was too good to be true, back to a 0.03mb connection again!
ash1ey
Message 20 of 23
Managed to get another test off and according to that its getting better. Doesnt feel that way at the minute:
This Test comprises of Best Effort Test:  -provides background information.
 Download  Speed
 483 Kbps
0 Kbps2000 Kbps
 Download speedachieved during the test was - 483 Kbps
 IP Profile for your line is - 2052 Kbps
Note: An Upstream test was not conducted on this line due to a technical issue. If your concern is related to upstream performance then please retry
