GlennW
Newbie
Message 1 of 9
Extremely slow downloads
Hi, not sure if I anyone could shed any light on why my download speeds are 0.177Kbps whilst my upload is 6.81Mbps.
My profile is 38.72Mbps and I have achieved download speed ratings nearing that in the past.
There are no reported issues in my area and I don't seem to have had any download issues since Infinity was installed 3 months ago.
I am connected to the HH3 by cable (wireless result in slightly better speeds), both modem and HH have been power cycled.
Is there any further information that I can provide that will help?
Any ideas welcomed.
Glenn
Edit: screen capture from speed checker:
8 REPLIES 8
mitchy
Message 2 of 9
Re: Extremely slow downloads
My speed dropped earlier and after an hour on the phone theres someone doing more tests on my line at the moment.
my speed went from 37mb to 5mb and is now sitting at 0.3mb
GlennW
Newbie
Message 3 of 9
Thanks mitchy, can I ask what region you're in?
I'm in Leamington Spa.
I will phone in the morning if there's no change but I'd rather not have any tests performed on my line as I have to do some additional work remotely this evening (from home over a VPN).
mitchy
Message 4 of 9
Bangor, Northern Ireland.
They had me using this site to test speed http://www.speedtester.bt.com/beta/
I think there still checking my line but the guy hasnt phoned back yet
GlennW
Newbie
Message 5 of 9
Thanks, probably very different issues then (or possibly the same issue but in different exchanges / cabinets).
I've used the beta speed checker and still achieve less than 1Mbs download.
All two-way speed checkers report that my upload is around 8Mbs, it's just my download that's slow.
mitchy
Message 6 of 9
I think it could be all over cause ive seen alot of people talking about slow speeds, it could be cause BT are releasing the 80MB upgrade 2moro
1. Best Effort Test:
Download Speed : 52 Kbps
2. Upstream Test:
Upload Speed : 7.17 Mbps
Message 7 of 9
Try www.speedtest.bbmax.co.uk
mitchy
Message 8 of 9
Well after rebooting my modem for the 4th time today it seems my speeds are back to normal.
37mb down and 8mb up
ratty1976
Message 9 of 9
i'm in leam too, crappy download speeds for me also, upload speed is fine.Smiley Frustrated
