Message 1 of 38
FTP FAILED TO RETRIEVE DIRECTORY LISTING. PLEASE HELP I AM ON BT INFINITY 2
Hi Friends
Please help crying out loud , i am having serious connection issues to my filezilla ftp server, it lets me login but then it says
failed to retrieve directory listing, i cantacted my server people and they tested it and said it is your router causing all this issue , sounds about right as i tried from 2 different laptops and my desktop also same issue contacted bt support as they said they refreshed the line and leave it for 48 hours before i can do port forwarding do you guys think it is the bt home hub 3.0 causing all these issues , if i change it to a different router will i get this problems sorted out, it was all working fine with good speeds of trasfer last 2 years with out any issues , from yesterday onwards i started getting this issue.Please help me friends how to sort this out.
this is my server test result.
Congratulations! Your server is working and assorted routers/firewalls have been correctly configured for plain basic FTP.
Feel free to test another one of your servers by entering its details below.
this is what i get from my ftp
Status: Connecting to 83.149.125.xxx.21...
Status: Connection established, waiting for welcome message...
Response: 220 (vsFTPd 3.0.2)
Command: USER raihanasulthana
Response: 331 Please specify the password.
Command: PASS *********
Response: 230 Login successful.
Command: SYST
Response: 215 UNIX Type: L8
Command: FEAT
Response: 211-Features:
Response: AUTH TLS
Response: EPRT
Response: EPSV
Response: MDTM
Response: PASV
Response: PBSZ
Response: PROT
Response: REST STREAM
Response: SIZE
Response: TVFS
Response: UTF8
Response: 211 End
Command: OPTS UTF8 ON
Response: 200 Always in UTF8 mode.
Status: Connected
Status: Retrieving directory listing...
Command: PWD
Error: Connection timed out
Error: Failed to retrieve directory listing
37 REPLIES 37
Message 2 of 38
Re: FTP FAILED TO RETRIEVE DIRECTORY LISTING. PLEASE HELP I AM ON BT INFINITY 2
I wonder if its the same issue as this?
https://community.bt.com/t5/Other-Broadband-Queries/New-firmware-kills-VPN/td-p/1196385
It may be affecting ftp remote listings.
If its a HH3A, check your firmware version, especially if its just stopped working.
Message 3 of 38
Thanks for your quick reply , but how do i find out the firmware version ?Do you think if i change it to a netgear router that will solve the problems ?
Message 4 of 38
Certainly be worth trying if you have a spare Netgear to hand or can borrow one.
Message 5 of 38
i got a spare netgear dg834pn , can some one please tell me how to set it up
Message 6 of 38
PPPoa, VPI 0, VCI 38 username anything@btbroadband.com, no password needed.
Message 7 of 38
problem is no socket to plug the ethernet cable coming from bt modem , it only got 4 ethernet ports to plug cables coming from the computers  there is no saperate port for cable coming from modem like in home hub 3 so dont know what to do now ? If i order a bt home hub 5 or is there any other good routers which can over come my problem ?
Message 8 of 38
If you are on Infinity with an Openreach modem, then there is a very wide choice of wireless routers you can use. Your Netgear one is ADSL only.
Message 9 of 38
Please advice me any good one which i wont get a problem on this ftp connection
Message 10 of 38
Look at the Infinity routers on this page.
http://forumhelp.dyndns.info/wireless/hh3replace.html
The TP-Link TL-WR1043ND is quite good, according to others who have it.
You could upgrade to a HH5 for free.
http://bt.custhelp.com/app/answers/detail/a_id/35097/~/how-can-i-get-a-new-bt-home-hub%3F
