coopa5
Message 1 of 2
FTP download speed problem??
Had my infinity installed on 08/02/2012, everything went smoothly but the problem i having is that when i try to FTP a large single on its own the speed is around 400-900kbps. but when i FTP lots of smaller files at the same time my speed is around 3700kbps??
Have tried several different FTP programs available all with same result.
my btspeedtester results all come back completely normal.
the strange thing is that it only happens at certain times of the day. (bt technical support advise me that my account is not restricted) but surely if it was it would affect my speed on everything not just when i try to FTP a single larger file???
any help would be greatly appreciated.
many thanks
1 REPLY 1
ironman123
Recognised Expert
Message 2 of 2
Re: FTP download speed problem??
Most FTP client programs have settings to set the upload and download max and minimum transfer speeds.
Have you checked that the global settings are setup properly,if they are set low then single connection settings will be overridden by the global settings.?.Just a thought.
