jlpetley
Message 1 of 24
FTTC Cabinet for EO Lines in Molesworth
Connecting Cambridgeshire has recently commissioned OpenReach to install a new FTTC cabinet in the village of Molesworth to switch over the Exchange Only lines and enable superfast broadband, something we've been promised for 3 years.  I recently received notification that the cabinet had been enabled for my area but when checking found that I couldn't upgrade and the status was still EO Line pending.
I raised this with Connecting Cambridgeshire who has spoken to OpenReach and they have been given the line "some properties were accidently missed" with no indication of timelines for correction.  Further checks show that all village property addresses with the postcode PE28 0QD are not able to order, yet all properties with the postcode PE28 0QF and PE28 0QH can order.
When the cabinet was being installed the engineers were working at the pole connection point that my telephone line runs from, so I'm certain the physical connection has been established.  The fact that the 'failures' appear limited to postcode addresses PE28 0QD suggests to me that this is more the case of OpenReach's database not being correctly updated rather than physical connections not being made. The problem is I cannot get any acknowledgement that that this is something potentially easily remedied.
Is there any way this issue can be given focus with OpenReach through the forum as Connecting Cambridgeshire appear to have been given the run around...?
23 REPLIES 23
gg30340
Message 2 of 24
Re: FTTC Cabinet for EO Lines in Molesworth
This is a BT residential customer to customer forum. Your post does not go to BT. You would need to continue to pursue this through Connecting Cambridgeshire and Openreach.
jlpetley
Message 3 of 24
But I am a BT customer and OpenReach is a BT company?  Previous posts that involved problems with OpenReach's database have been resolved through the assistance of BTCare forum champions?
Webby
Message 4 of 24
Hopefully a moderator will be along shortly to offer their assistance.
pompey1898
Recognised Expert
Message 5 of 24
Has the cabinet been installed in Molesworth, as it has been for Old Weston, or outside the Bythorn exchange ?
Webby
Message 6 of 24
imjolly
Message 7 of 24
Write to openreach and see if you can get database updated  if you get an auto reply then send again until you get reply from an actual person
https://www.formwize.com/run/survey3.cfm?id=7214&embed
jlpetley
Message 8 of 24
Thanks Webby.  I've a call with OpenReach that is doing the rounds.  I'm sensing it could be a DB update issue, although when the engineer was installing the box he did say that it only had had a card sufficent for 50 properties, i.e. half the village.  At the time the assumption was that this would only be an issue if and when people signed up.  Perhaps this is a physical limitation for switching over EO Lines and frustrating as such boxes have capacity for 288 (I believe) connections.
jlpetley
Message 9 of 24
Thanks imjolly.  Yes I've a call with OpenReach although to date they have just referred me back to the checker that tells me what I already know, i.e. 'pending EO Line technology".
Webby
Message 10 of 24
The 50 ports thing will just be the initial line card. Current take up of FTTC services is only around 20% so if you have a cabinet that serves 200 lines, at the moment expected take up will only be about 40 lines. Of course once the initial line card hits capacity, Openreach will add another. I think you need to chase up the records issue, perhaps the moderators on here can help. I know they've had success in the past.
