Message 1 of 7
FTTC DLM
Hello everyone. I used to be with Sky broadband on the 38mb/s tier. I used to get 33 mb/s.
My line with BT up to 52 mb/s was *just* activated and I am getting speeds of 21 mb/s. Will this slowly go up to 33 mb/s during the first 10 days of service? Thanks.
6 REPLIES 6
Message 2 of 7
Re: FTTC DLM
Can you post hub stats if hh6 then advanced settings then technical log information
enter phone number and post results remember delete number but leave exchange and cab
https://www.dslchecker.bt.com/adsl/adslchecker.welcome
Message 3 of 7
Re: FTTC DLM
BT Speed Test
Sky this morning on the same line, same socket etc.
Product name:
BT Hub 6A
Serial number:
+084316+NQ94590721
Firmware version:
SG4B1000E01E
Firmware updated:
01-Jan-0001
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
0 Days, 4 Hours 13 Minutes 53 Seconds
Data rate:
6.04 Mbps / 23.26 Mbps
Maximum data rate:
6042 / 26388
Noise margin:
6.1 dB / 5.8 dB
Line attenuation:
26 dB
Signal attenuation:
0 dB / 26 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
663 MB Uploaded / 4087 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
BTHub6-7P9H
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-7P9H
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
5C:B1:3E:16:4A:1B
Software variant:
Boot loader:
0.48.8-sec
Message 4 of 7
Re: FTTC DLM
Which exchange and cab. You deleted from dslchecker results
Message 5 of 7
Re: FTTC DLM
Peterston-Super-Ely exchange
Cabinet 3
Message 6 of 7
Re: FTTC DLM
If you can maintain a stable connection 24/7 for 7/10 days the DLM should activate G.INP which should lower noise margin and give you an increase in connection speed
Message 7 of 7
Re: FTTC DLM
Thanks for your help!
