I used to live about half a mile away from my current house. I had FTTC in the old property and was told when moving that the new premises i would be able to upgrade back to it soon after moving. I have just gone to upgrade it and learnt that I can get FTTH which i dont really want, due to having recently decorated and been told a lot of drilling is involved.
My old house uses the same cabinet so I cant understand why the new property cannot just have FTTC, or is this something i can pay to get done?
If you are now half a mile further away from the cabinet you are probably too far for FTTC. You seriously don't want the huge advantages of FTTH because of a bit of extra decorating?
A lot of drilling? 1 hole from outside which will be covered by the ONT.
Thats odd, as was told there was drilling inside as well?
Does the router inside have to be on the main line or can it be on the sub line?
There is no main line or sub line. There is a fibre optic cable which plugs into the ONT.
THIS pretty much explains it.
Its always best to use the dedicated FTTP team rather than normal sales. 0800 587 4787
