Amunre
Message 1 of 4
FTTC when and if will my line be enabled
I am still struggling with less than 1.5 Mbps for over 3 years now. I have been able to ascertain that there are certain cabinets served by Lisbellaw exchange that are FTTC enabled. My line is apparently served by cabinet 5 which is not FTTC enabled. It seems that my line is too long to gain any benefit from fibre to the cabinet and therefore I will be stuck with a lousy speed forever and a day. I have seen words to the effect "we are looking at alternative solutions". What those solutions are, nobody seems to know. I wonder if there are any experts out there who might know what these "alternative solutions" might be. Of course it's impossible for a mere consumer to speak directly with anyone in Openreach.
“Dogs come when they're called; cats take a message and get back to you later.”
Mary Bly
3 REPLIES 3
Webby
Message 2 of 4
Re: FTTC when and if will my line be enabled
Can you put your number into here http://www.dslchecker.bt.com and post up a copy of the results including the exchange and cabinet number please.
Webby
Message 3 of 4
Cabinet 5 on that exchange was enabled in 2011.
If you're too far from the cab then perhaps in future you may see some FTTrN or FTTP.
brianhes
Message 4 of 4
All you can do is pester your local BDUK delivery project and your elected representatives.
Similar situation promised improvements six years ago, cabinet enabled a few years ago, but too far for it it be of any use. Have seen planning application for an infill cabinet, but that will still be at least 3km.
