Message 1 of 5
FTTP Availability
Checking on OpenReach, FTTP is available on the property address, but on BT the website, it informs me that FTTP is not available. Any ideas what to do?
4 REPLIES 4
Message 2 of 5
Re: FTTP Availability
@ab0
You would need a working BT Retail phone number, before the database will show the correct details.
If you do not have a phone number, then you will have to place an order for a phone line first.
Message 3 of 5
@Keith_Beddoe
We have a working landline. Used the landline number as required to check availability of FTTP, but that made no difference.
Message 4 of 5
I assume it was a BT Retail phone line, is that correct?
If it is a BT retail number, then call the FTTP Team on 0800 587 4787, they should  be able to help.
Message 5 of 5
if you have a BT phone line then enter number here and post results  this will show if FTTP available to your number
