Message 1 of 2
FTTP Hardware
Hi there,
Having FTTP installed next week and the space where the old line comes in is fairly limited. I assume the fibre will follow the same route.
Can anyone confirm what ONT Openreach engineers are installing these days?  I assume this but wanted to check.
Thanks!
1 REPLY 1
Message 2 of 2
Re: FTTP Hardware
The make of ONT will depend on the head end equipment you will be connected to but the size is about the same.
You can have the ONT installed practically anywhere and does not depend on where your main telephone socket is situated. Discuss with the installer on the day.
