Message 1 of 4
FTTP Install?
I've recently had a letter through the door telling me I can now get ultrafast Full Fibre 900 compared to my current best at 20Mb. I'm hoping someone call help me with some questions over this?
1) If I order I assume I get fibre run in to the property at no extra cost?
2) Does this utilise existing entrances/boxes or do I need more?
3) Does the old copper line get removed?
4) What happens  in the future if I decide to revert to Fibre 1, is this allowed and would I now get the full 50Mb given it's using fibre not copper?
5) Same as above but can I still order the standard fibre products with other provides?
TY 😁
3 REPLIES 3
Message 2 of 4
Re: FTTP Install?
Correct
No, an ONT needs to be fitted.
No.
You can order Fibre 1 from the start if that's all you want. You would get full 50Mb
As long as the other provider supplies those products via FTTP then yes, no reason why not.
TY 😁
An ONT.
Message 3 of 4
Re: FTTP Install?
Given I am already on fibre 1 with 20Mb how would you get BT to change it over to fttp or is it done automatically where available if you place a new order?
Message 4 of 4
Re: FTTP Install?
Just place an order for FTTP, call the FTTP team 0800 587 4787
