Message 1 of 2
FTTP ONT and using own Router/Modem
Hi, I've tried searching the forum for an answer and have seen varaints of my question but not sure anyone has had the exact same question.
I am moving to a new build property at the end of the month which will have FTTH avaiable. The developer has confirmed that there will be an ONT present when I move in.
I have a router that I use currently (no modem within) it's an Asus RT-AC3200.
My question is - does the ONT act as the WAN interface and can I plug the RT-AC3200 into the ONT or would I need to also connect the hub I get with the order?
Keen not to have 3 boxes ONT>BT Hub>RT-AC3200 if possible.
Thanks for any help with this
1 REPLY 1
Message 2 of 2
Re: FTTP ONT and using own Router/Modem
The ONT acts like a modem so you can just plug your router into it with the WAN port.
____________________________________________
BT FTTP 500/75 + pfSense + 4 x UniFi Wifi 6 Pro
