markcoster
Message 231 of 292
Re: FTTP Problems - 0.86Mbps down
Agreed it would seem the problem has passed. Lets hope they've worked out the issue.
georgelnx
Message 232 of 292
@MarkC
Unfortunately Mark I doubt BT/Plusnet/IDnet/Openreach have done anything today. It's the weekend and the team looking after this tends to keep weekday office hours. This is par for the course, 18 hours of slowdown followed by a period of good speed then back to rubbish. This has been happening for well over 12 weeks so the pattern is there.
JTG6
Message 233 of 292
Sadly I completely agree with George...
JTG6
Message 234 of 292
And the speeds are going down again.... I'm getting poor picture quality on BT TV HD channels again and the last speedtest from BTW was 85Mbps, though you'd think that was more than enough for HD...
Getting really, really fed up with BT's failure to fix this problem.
georgelnx
Message 235 of 292
@JTG6
I wasn't online last night after 6pm so didn't notice any slowdown. This morning things are running fine here.
However I cannot beliieve that at 80Mbps your BT TV channels don't work properly. That speed is well in excess of any minimum which I think is 2Mbps. It does beggar believe our fttp setup. So much for the future of telecomms.
JTG6
Message 236 of 292
Hi George - I was in bed shortly after my last post, but speeds this morning are ok (270Mbps).
georgelnx
Message 237 of 292
Some little reading The Guardian - Broadband Rage
-AndyH-
Expert
Message 238 of 292
I posted this to the MKBAG and TBB forums...but I think it sums up BT on issues like this:
https://status.aa.net.uk/1890
legitimise_sailing
Distinguished Expert
Message 239 of 292
TBH I don't think Crouch End is anywhere near Milton Keynes.
To say thanks for a helpful answer, please click the white star
-AndyH-
Expert
Message 240 of 292
Well done...you've clearly got a good grip on geography.
