Message 271 of 292
Re: FTTP Problems - 0.86Mbps down
Sorry I wasn't around last night, did you both get a general slowdown or was there a difference ebwteen the speedtest.net results?
Message 272 of 292
I was getting the same results from BTW as I did from Speedtest.net.
This evening though, speeds on BTW are all over the place - first test was 205Mbps, next was 258Mbps then 217Mbps, then 198Mbps.
Speedtest is giving equally odd speeds:
MK Server
1. 128Mbps
2. 237Mbps
3. 175Mbps
London Server (Namesco)
1. 179Mbps
2. 131Mbps
3. 147Mbps
The severe slowdown doesn't seem to have happened for a while, but speeds are far from consistent.
Expert
Message 273 of 292
I am down to 40Mbps...20ms pings on speedtest.net
Expert
Message 274 of 292
Very poor...
Message 275 of 292
I'm down to 5-10 from a 80 connection. Thought sky on demand was doing poorly earlier. Did the btw speed test then and it all looked good.
Message 276 of 292
I wasn't able to test when your speeds dropped, but right now I'm getting around 280Mbps.
Message 277 of 292
Just ran a speed test at Think Broadband and got the following result:
Any idea why there is such a massive difference between the green TBB and yellow HTTP numbers?
I saw a post on another forum of another FTTP customer and both sets of numbers were all within 309-312Mbps.
Distinguished Expert
Message 278 of 292
Congestion on a single HTTP stream - could be throttling by the ISP, your browser, small RWIN on your TCP settings, anti-virus or firewall blocking.
Try another browser, try another PC.
To say thanks for a helpful answer, please click the white star
Message 279 of 292
Thanks legitimise_sailing. I'll try that this evening.
Message 280 of 292
Bt called today to say they've completely replaced the line card at the bradwell abbey exchange on fishermead. They believe this is the cause of the downstream speed problems.
Let's see, I've advised them I'd monitor it for a week.
