Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
my exchange (Goole) is due to be upgraded to FTTC/P in June 2014. To get FTTP do I need to pay for the fibre cable to be installed to my property like FTTPoD or is it installed for free when I signup to infinity 3 or 4 package?
thanks.
Someone Solved Your Question? Please let other members know by clicking on ’Mark as Accepted Solution’ | Try a Search See if someone in the community had the same problem and how they got it resolved. |
@jac_95
I Also live in goole and was pleased to fiond out that BT Infinity is coming to the area. However, the brand new house (month old) i have just moved into has an exchange only line, and was wired up by openreach after it was already announced. because i dont have a cabinet im aware i wont be able to get FTTC, but will i be able to get FTTP direct from the exchange?
I know i will find out in the coming months but im just annoyed at the possibility of a brand new house not supporting modern internet speeds.
Regards
Kyle
Hi
I believe that there are not many exchange areas in the country that have both FTTP and FTTC. Either way they would be done on a PCP area so if your PCP goes to FTTC then you could only get FOD.
But My Exchange (MYGOO) is declared as FTTC/P. So with openreach literally installing my line as an Exchange only line in the past couple month whilst fibre upgrade is apparent in town (new cabinets big reels of cable been laid etc), then is there any chance they would have put fibre in direct? and if so, is there any telltales at home i could look for? Because there isnt a cabinet been put outside the exchange to accomodate so i will be fuming if my new house can only deliver 20mb but my old 100+ year old house can do 80 😐
If you are on an Exchange Only (EO) line you will not be able to get FTTC. It will require Openreach to install a cabinet out side the exchange which will then allow you to get FTTC. This is apparently going to happen to EO lines but not anytime soon.
You might be able to get FTTP if that is available in your area.
You can use this checker to see if you ca get it.
http://www.productsandservices.bt.com/products/broadband/faster-internet
FOD isn't available at that exchange, it seems very random which can get it and which can't.
The exchanges that can get it are marked 'FTTC/P & FOD 'whereas yours is only marked 'FTTC/P'.
This thread is over a year old so hopefully the OP has been sorted out!
