Message 1 of 9
FTTP gaming latency/ping issues
Hi all
got BT FTTP 150 installed recently.
speedtest and BT speed checker show >100mbps - so that’s fine.
Gaming is an issue though. Various games show packet loss indicators. Online gaming is not really playable any more. No issues previously with plusnet 50mb broadband.
I wonder if someone could help?
Sort of wish I hadn’t left plusnet now.
ive looked at other forum posts and seen comments about “ stable “ options. I’d forego a little speed to get rid of the packet loss
on PingPlotter my packet loss seems to be at 31.55.185.181 with 96% lost
id be grateful for any assistance.
steven
Tags (4)
8 REPLIES 8
Message 2 of 9
Re: FTTP gaming latency/ping issues
Images are too low res for me to read, which hop are you losing packets at?
Message 3 of 9
Thanks for looking at this.
Forum wouldn’t let me upload any larger file size.
hop 3 is the issue.
I believe that things are fixed now though. last night I removed power line adapters from my network and although hop 3 still shows 76% packet loss; a test just there shows (final) hop 8 to bbc.co.uk
operates between 20 and 30ms. That, I can definitely live with!
weird that hop 3 is still a mess, but if the end result is still low ping, that’s ok, right??
Message 4 of 9
@Skg959
I am sure, looking through the forums, Powerline Adaptors are known to cause speed issues/bottlenecks.
Maybe worth having a look over the forms for Poweline adaptor posts to have a look.
How are you currently connecting from the Router to the PC in question?
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 5 of 9
Hi.
connection is via WiFi.
Im aware that Ethernet would be much more stable, but not a long term solution to have cables running all over the house.
Message 6 of 9
Hi.
Thought I’d post the solution which worked for me.
I removed the 3rd party power line adapters that I had already in place. I disabled uPNP on my router - I’ll test enabling that again in due course.
using WiFi I was getting the packet loss and ping spikes detailed in this post.
I am now using the Wifi extended disc from BT like a power wall adapter.
it’s plugged into the wall in my kids playroom. The disc is connected to a cheap 4 port switch via the Ethernet  on the back of the disc .
the switch is then connected via Ethernet to a PS4 , a pc and the sky q mini box.
no packet loss indicator on COD on PS4 ! 🙂 no rubber banding or stuttering! It’s like night and day 🙂
On PC , ping in the 20’s for fortnite.
On PS4 , ping in the 20’s for forntite. 0% packet loss!  (Screen shot)
Message 7 of 9
What program did  you use to check this?
Thx
Message 8 of 9
Hi. The program was PingPlotter. Really useful!
Message 9 of 9
Thx
Using it now.
Ty
