Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Hello all, I am now finally able to order fibre where I live and so have ordered the Infinity 3 package. This is a mixed copper and fibre development, with only copper deployed after moving in a year ago (so currently on ADSL). The fibre was run to the manifold in the summer but I now have installation dates for the final stages.
I have seen the components that will get installed with FTTP and would be happy to have the CSP on the outside wall next to the front door, where the BT duct emerges and where the copper currently enters the house through the wall.
I would like the ONT, BBU and hub in the cupboard under the stairs, where the current master socket is located. However, this is in the middle of the house, so the Openreach engineer is going to have to find a way of getting the fibre between the two locations.
The order email states:
The email states the engineer should:
I am fairly sure the existing copper runs up the wall, through the ceiling void, then down a wall into the understairs cupboard. Being a mixed copper/fibre development, the developer (one of the big UK housebuilders), should have followed the Openreach guidelines and put in a duct between the external BT duct and internal master socket location, but this is too 21st century for them so has probably been ignored. That said, there is a duct or ducts that goes to that location and bring in the main electricity feed and communal TV fibre through the floor, though I don't know where they enter the house.
My options are:
Number 3 seems ideal if it 'just' a case of digging a hole near the front door to get to it, though care would be needed not to damage the existing cables inside and ensure it remains watertight.
If I go for option 2, how thick is the fibre tube that runs inside the home? I have dot and dab walls and so could it fit in the void between the plasterboard and blockwork?
Thanks,
James.
Solved! Go to Solution.
i really wanted FTTP 😞
Thanks for the reply. If it is about the same as the copper then it should go behind the plasterboard and naturally I would have to prepare the route.
I cannot see any reason for problems due to proximity of mains cable as the fibre, unlike copper, should be immune from the electromagnetic interference. A fibre voice line would be good as the master socket is fairly close to the electricity meter and consumer unit, possibly giving me the buzzy line.
If it were me preparing for the installation I would go to my local plumbers merchant (or B&Q) and get a coil of 8mm plastic piping and have it already in place (various lengths available). It will easily go behind dot & daub dry lining.
To conclude my thread, I finally had the FTTP internal installation done yesterday. (The long delay from ordering was down to failure of BT Retail's ordering system after a reschedule.)
I went with my middle option of going behind the plasterboard and thanks to pippincp's suggestion I put some tubing in place. Rather than plumbing pipe, I bought some inexpensive flexible conduit, fed some string through it first, then fed the conduit behind the plasterboard along the wall, into the ceiling across the hall (using a hole cut under the bath to help feed it) then down the waste pipe void, which was on the opposite side of the wall. Sounds easy, but there was quite a bit of effort needed.
I had a very helpful Openreach installer who was happy to feed the fibre through the conduit, where I pulled it through and he fed it in. Something else to note is that one end of the 30m fibre reel available has the connector to the ONT pre-fitted. Even if not using my conduit, the cable feeding has to start from the ONT location.
The installer was impressed with the method and agreed it is much better than having the fibre on view. A fourth option mentioned by the installer was to run the fibre externally to the back of the house, then in through the utility room where a cable on the skirting might be less intrusive. I had thought about that before putting in the conduit, but was not keen on having so much exposed on the outside wall.
I have a bit of effort now to refill all the holes. Most were created with a hole cutter in the drill so i still have the cut-outs. As could be expected, there were more obstructions than expected so there are a lot of holes to do. Having lived with my hall looking like Swiss cheese for a month and a half, I'll be glad to have it back to normal.
Happy it all went to plan!
