Message 1 of 22
FTTP installation
I currently have a small white internet box with a wire running from it to a BT home hub - both are situated in my gaming room which is upstairs in a detached house and usually get 80mbps. I have just upgraded to FTTP 500, I have checked https://www.broadbandchecker.btwholesale.com/#/ADSL which states for installation it will be one stage.. can this be done in a way so I can keep modem/hub in room and run my gaming set up through Ethernet ? Thanks in advance
21 REPLIES 21
Message 2 of 22
Re: FTTP installation
It sounds like you already have the BT ONT box where the fibre coming into your house terminates and then you have an Ethernet cable going from this box to your router, plugged into the WAN socket
As such, if I’m understanding correctly, you have all the equipment, so your upgrade would be a behind the scenes job to open up your speed to what you’ve now signed up to
Message 3 of 22
Yes it’s a little white box with one WAN socket and nothing else, that connects directly in to home hub. It’s been great and have always had consistent speeds.. just looking something with a bit more bite to it now. Fingers crossed it’s all easy enough.
Message 4 of 22
You will need to discuss this with the Openreach engineer when they arrive. I assume that all you have at the moment is a standard phone socket on the wall, with the home hub and phone plugged into it?
Or do you have a white Openreach modem plugged into your phone socket like this?
If you do, then that will not be needed, and an Openreach ONT will be fitted, and BT will send you a smart hub 2, which will plug into it.
Message 5 of 22
I have no idea how BT did this initially but there is no phone line in my gaming room, it’s literally only a small white box with a wan socket which then goes to a hub. The main phone line is downstairs, to my knowledge there is no wire connecting up to my room either.
Message 6 of 22
I think you need to supply some photos, of all the various boxes involved.
Message 7 of 22
I can’t get a picture that is small enough to post as it’s saying file size too big.. but it’s literally white socket with a wan cable connecting to my hub, no filter, no Ethernet or no other modem involved.
Message 8 of 22
use the camera icon
Message 9 of 22
Like one of these?
Message 10 of 22
Yes - but just with a single opening
