Message 11 of 14
Re: FTTP red end cat 5 question
Probaly not related but.!!!!!!!!!!!
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 12 of 14
if you’re getting the speeds you should when connected directly to the ONT with the Smart Hub it sounds like there’s either a fault with your internal wiring or it’s just not up to scratch.
Is it a New Build, if so ask the Developer to send their Data Cabler round to check it.
Message 13 of 14
Yep I may do that.
thanks
ian
Message 14 of 14
They probably got the sparky to do it and he used a bit of twin and earth. 😃😃
