AndyBull
Message 1 of 4
FaceTime and HH4 poor video
Have just switched from an Apple Airport Extreme running my Wifi through a HH3 with no issues.
Decided to swap to a HH4 as it meant only 1 device instead of 2.
Been fairly pleased until using FaceTime, the video is really poor out to my daughter.
Have swapped the Airport Extreme back into the system and bingo all back to normal.
Are there some Ports the HH4 is blocking that the Apple protocol needs.
3 REPLIES 3
StuartH
Moderator
Moderator
Message 2 of 4
Re: FaceTime and HH4 poor video
Hi AndyBull
Not aware of this issue but can have it raised to see if we can find a resolution.
Email me using the contact the mods link in my profile you will find it in the section 'About Me'.
Stuart
xmb
Message 3 of 4
Try logging into the HH4 and see if you Apple Mac computer has a device name with spaces or : characters. this seems to cause a lot of network related issues. If you do find such a name listed you need to change the name in your Mac.
Go to System Settings > Sharing Click edit in the Computer name box and enter a name or just change the name slightly (but no spaces). Then restart your mac and log backinto the Home Hub to confirm the name is now seen without od chaacters or spaces.
This problem seems to occur most with Macs that have been upgraded from previous OS X versions, as it seems to use a computer name with MAC addess added.
AndyBull
Message 4 of 4
Thanks for that, have heard this before but have never seen it on either My MacBook or iMac in seven years of updating OSX.
To confirm no spaces or dodgy characters in the device name showing up on the HH4.
Thanks for looking.
