Message 1 of 2
Factory Reset of Home Hubs
Just a curious question: Is it a good idea to conduct a Factory Reset of Home Hubs occasionally?
I ask this because my hub has 275 pages of Event Logs which might be taking up some memory or processing resources in the hub.
1 REPLY 1
Message 2 of 2
Re: Factory Reset of Home Hubs
It may be easier to say it won't do any harm if you decide to to that now and again and not on a daily basis.
If you do decide to do it remember to turn off Smart Set Up as it can cause problems.
See link
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
