Hello
Can I be put on "Fast Path" please, had been using a TP-link router which was connected for over 30 days after a connection issue was sorted 2 months ago, thou fast path was not one of the states on the status page the ping never dropped in this timespan.
Have been using a HH4 which I purchased and been waiting for DLM to do the job, 12 days connected no change, stats below.
Thank you.
1. | Product Name: | HomeHub4 |
2. | Serial number: | +076281+1714000731 |
3. | Firmware version: | v0.07.05.03230-BT (Type B) Last updated 26/6/2018 |
4. | Board version: | 01B |
5. | DSL uptime: | 11 days, 21:02:53 |
6. | Data Rate: | 1264 / 20531 |
7. | Maximum Data Rate: | 1268 / 22688 |
8. | Noise Margin: | 6.1 / 3.1 |
9. | Line Attenuation: | 1.2 / 5.5 |
10. | Signal Attenuation: | 1.7 / 10.3 |
11. | Data sent/received: | 2.4 GB / 46.7 GB |
12. | Broadband username: | bthomehub@btbroadband.com |
13. | BT Wi-fi: | No |
14. | 2.4GHz wireless network/SSID: | BTHub4-353Q |
15. | 2.4GHz wireless connections: | Enabled (802.11 b/g/n (up to 144 Mb/s)) |
16. | 2.4GHz wireless security: | WPA & WPA2 (Recommended) |
17. | 2.4GHz wireless channel: | Automatic (Smart Wireless) |
18. | 5GHz wireless network/SSID: | BTHub4-353Q-5GHz |
19. | 5GHz wireless connections: | Enabled (802.11 n (up to 300 Mb/s)) |
20. | 5GHz wireless security: | WPA2 Only |
21. | 5GHz wireless channel: | Automatic (Smart Wireless) |
22. | Firewall: | Default |
23. | MAC Address: | 48:8d:36:23:98:17 |
24. | VPI/VCI: | 0/38 |
25. | Modulation: | G.992.5(ADSL2+) |
26. | Latency type: | Interleaved |
27. | Software variant: | - |
28. | Boot loader: | 0.5.0-BT (Wed Nov 12 11:47:59 2014) |
Solved! Go to Solution.
great connection with your attenuation you must live almost next door to exchange
I have asked mod to help change your latency to Fast they will post a link here - complete form and mods will get back to you in 2/3 days
@Railwayman Please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Neil
Thanks for the quick replys, have filled out the form and yes I am about 150yds from the exchange on an EO line.
@Railwayman good speaking with you there, this is due to complete tomorrow so just keep an eye on your connection. Let us know on Thursday how you're getting on.
Thanks 🙂
Fast path was enabled yesterday afternoon, DLM then kicked early next morning resulting in a reduction of 50% in my ping to London servers (18ms to 9ms) and an increase in download speed of .5 Mb so all in all a great result.
A big thankyou to all invoved.
Just one final question, if in the future I use my TP-Link router (AC 1900) will these settings be retained?
Gary
@Railwayman great stuff, it all completed sooner than expected 🙂
A change of router won't affect your settings as this change was made at supplier level.
