Message 1 of 1
Faster download on wifi than wired Ethernet
I have G.Fast and a Home Hub 2
When I use a speed checker on my iPhone 7 I get 120-150Mbps down
When I then do the same test on my Ethernet (cat7 cable) connected Win10 PC I get 80Mbps
Upload speed is typically 20Mbps on both, but the PC periodically drops to 8Mbps
The Ethernet adapter on the PC is set to 1000Mbps
When I run the test on the BT wholesale tester https://speedtest.btwholesale.com/ and do an advanced test it tells me the IP profile for download is 73Mbps which as far as I can make out from the help file is effectively a limit on the speed, although I that were the case I shouldn't be able to get the much faster speeds through wifi.
Any suggestions on what's going on here gratefully received
Nick
