My hub will only sync at 7mb down and 12mb up. When I try and run the fault website it stops at 99%. Would is best to contact about this?
Thanks!
Have. You checked you have a dial tone? If so dial 17070 option 2 should be silent and best with corded phone
can you post hub stats. If hh6 go to advanced settings then technical log information
Sadly we don’t use the landline ever and don’t have access to a phone to test this.
Info from HH6 below:
BT Hub 6A
+084316+NQ71690714
SG4B1000E01E
27-Aug-2019
1.0
1.105.0
0 Days, 1 Hours 15 Minutes 16 Seconds
10.00 Mbps / 6.91 Mbps
12657 / 8380
8.7 dB / 7.4 dB
23.8 dB
0 dB / 23.8 dB
0/38
G_993_2_ANNEX_B
Fast Path
37 MB Uploaded / 433 MB Downloaded
bthomehub@btbroadband.com
Not active
Channel 1
Channel 36
WPA2 (Recommended)
Mode 1
On
F4:6B:EF:2B:8E:FD
Its a pity you don't have a phone as it looks like a possible phone line fault. I'd guess at only one wire connected but as you cannot confirm the problem you'll have to take the longer broadband fault report loop.
Thanks for the reply. How do I start that process?
I will try and source a phone.
If you do not get dial tone, or there is noise on the line, then you need to report it as either no dial tone, or a noisy line. Do not mention the broadband problem, otherwise it will end up in the wrong fault queue, and take much longer to be fixed. There are plenty of people who can fix phone faults, but not as many broadband people.
Once the phone fault is fixed, then the broadband will get better.
Found a phone in the garage and there is no issue with the phone line....
When I try the fault finder on BT it freezes at 99% every time.
