-Mike-
Message 1 of 2
Fault with DNS name resolution - timeouts
I have been having problems recently using the internet, due to what appears to be a fault with the BT DNS service.
For the past 24+ hours DNS resolution from the default servers picked up on my Home Hub 4 has been "hit and miss" - timing out more often than returning a response.
Primary DNS: 213.120.234.14
Secondary DNS: 213.120.234.30
Even when there is a DNS response it can be very slow.
Symptoms are the same from different PCs and continue after the Home Hub has been rebooted.
The result is that it is close to impossible to use the internet as web pages fail to load, or when they do load they are very slow to start to open
The ideal solution would be to be able to change DNS servers on the Home Hub to use OpenDNS and workaround has been to manually change DNS Name Server on individual devices - but what is the fix?
Additional information and examples from the checks I ran as follows:
First of three attempts with a nslookup:
nslookup www.google.com
Server:  BThomehub.home
Address:
DNS request timed out.
    timeout was 2 seconds.
*** Request to BThomehub.home timed-out
Second attempt
Address:
Third attempt
Server:  UnKnown
Address:  ...
Non-authoritative answer:
Addresses:  2a00:1450:4009:803::1011
          173.194.34.116
          173.194.34.115
          173.194.34.113
          173.194.34.114
          173.194.34.112
Checking on the BT Home Hub I see
Direct DNS Query on the primary DNS Server
nslookup www.microsoft.com 213.120.234.14
Server: indnsc91.bt.net
Address: 213.120.234.14
*** Request to indnsc91.bt.net timed-out
Same on the secondary DNS server
nslookup www.microsoft.com 213.120.234.30
Server: indnsc100.bt.net
Address: 213.120.234.30
*** Request to indnsc100.bt.net timed-out
However if I use OpenDNS I get a quick response:
nslookup www.microsoft.com 208.67.222.222
Server: resolver1.opendns.com
Address: 208.67.222.222
Address: 134.170.184.133
Aliases: www.microsoft.com
toggle.www.ms.akadns.net
g.www.ms.akadns.net
1 REPLY 1
gg30340
Message 2 of 2
Re: Fault with DNS name resolution - timeouts
Have you tried turning off your Homehub for about half an hour then switching it back on. This may prompt it to connect to different a server.
