Message 1 of 3
Faulty Red Ethernet Cables from TALKTALK package
Hi Everyone
The BT Engineers are finding several instances of Red Ethernet cables been faulty in the G-Fast 150mb Router package sent to Talktalk  customers .In my case the same applied and I was told this in not uncommon .Does anyone know what the exact cause is?. Is it a bad connector, or no continuity through the cable or otherwise. I was told the matter has been reported back to Talktalk but the issue remains at present.
Regards Salty1
2 REPLIES 2
Message 2 of 3
Re: Faulty Red Ethernet Cables from TALKTALK package
@Salty1
This is a BT Retail customer forum, and the engineers are from Openreach not BT Retail. BT Retail have nothing to do with Openreach.
I suggest that you post this message on the TalkTalk user forum, where I am sure it will be appreciated.
The TalkTalk Members Forums
Message 3 of 3
Thanks for the advice
