Stesmith
Message 11 of 19
Re: Faulty hub6
Bought and tried a TP-Link wireless router but ADSL light continually flashing and device never synchronised. Plugged smart hub back in and it started working! For now! Have no idea what is going on now. Can anyone suggest anything?
licquorice
Message 12 of 19
Re: Faulty hub6
Which model TP Link router is it?
Stesmith
Message 13 of 19
Re: Faulty hub6
TD-W8968
licquorice
Message 14 of 19
Re: Faulty hub6
That is an ADSL modem/router rather than a VDSL modem/router. You need to look at either the 9970 or VR600
I assume you have Infinity rather than standard broadband.
Stesmith
Message 15 of 19
Re: Faulty hub6
Yep got infinity. Cable to cabinet across the road then down phone line from there. Was advised in maplin that I'd need an ADSL router cos of this. Guess I got wrong advice?
licquorice
Message 16 of 19
Re: Faulty hub6
Oh dear, Maplin don't seem to have much of a clue. You were advised on here to get a VDSL modem/router.
ianonline999
Message 17 of 19
Re: Faulty hub6
This is what you need TP-LINK Archer VR900 AC1900 Wireless Dual Band Gigabit VDSL2/ADSL2+ Modem Router for Phone Line Connections
Stesmith
Message 18 of 19
Re: Faulty hub6
Bought Nd set up TP-LINK VDSL TD-W9970 today. Immediate connection to all devices including those that have failed to connect to BT smart hub for 4 weeks. Seems like problem is solved. Poor quality BT kit. Thanks to all contributors here for your help.
Keith_Beddoe
Message 19 of 19
Re: Faulty hub6
But it does not look as nice as the hub 6 Smiley Wink
Its all about marketing these days, it does not matter if it does not work very well, as long as it looks good.
