Message 21 of 24
Re: Fed up of capped speed
My DSLAM's a Huawei and my PCP's the newest style (if anyone could tell me what make these are that'd be interesting ;)). But I know G.INP is enabled as I've a HG612 on a Huawei modem, but I'm convinced there's some sort of problem between the cab and our house, as 600m isn't that far really, even when you take into account the VDSL drop off.
I just wish we had our own JDSU type device to find out this sort of thing!
Message 22 of 24
attenuation for VDSL is around 13.5 dB per Km times two. So should be lower than 20 dB if distance is accurate
Also you should not have interleaving active if the line was clean
Message 23 of 24
Yep, 24.5 for the down. I think the lack of an up attenuation is a glitch on the modem's part.
Message 24 of 24
@umpire yep, got the .89 and .69 mixed up 😛
