Message 11 of 23
Re: Fed up with speed issues
Hello,
Could one of the mods look into this please.
Distinguished Guru
Message 12 of 23
In order to rule out the Homehub as potentially being the device responsible for your speed loss, you can connect the Openreach modem directly to the PC and see if the speed improves.
To do that follow these steps:
Step 1: Remove the homehub from the modem cable
Step2: Connect your pc/laptop to the modem via the cable instead
Step3: Open network and sharing centre on windows and click set up a new connection or network
Step4: Connect to the internet then click make a new connection Broadband PPPoE
Step5: Username bthomehub@btbroadband.com and the password as BT
Step6: connect, If it doesn't, keep pressing try again until it does.
However, please note that this will stop any other access apart from the PC
If not, I'll try again 🙂
Message 13 of 23
Thanks Ray, wil try that. If that is the issue that would explain the dropping speeds but not the sudden drop in my IP line profile speed? Its saying max achievable speed i can get is now around 53mbps., when it was clearly more then that.
Distinguished Guru
Message 14 of 23
As you know, your IP Profile is within the estimate for your line. However, if it continues to fall it could indicate a line fault
Message 15 of 23
Yes, but thats what im saying. The estimate for my line has dropped in the last week or so. It was saying i could get speeds of up to 76 mbps.
Distinguished Guru
Message 16 of 23
BT have committed to supplying realistic estimates.
Message 17 of 23
as you have the modem and hh4 you probably have had infinity for more than a year and in that time more customers have been added to your cabinet and the data from these connection is used to update the estimates and make the estimates more realistic - unfortunately that normally means the estimates are lower now than a year ago
Message 18 of 23
I understand that but it's only dropped in the last couple of weeks??
Message 19 of 23
I suppose it depends on how often you run the dslchecker as estimate may have dropped weeks ago
Message 20 of 23
Well it stands to reason if I was getting 64 mbps on the test results I posted earlier it has dropped since then.
