Message 1 of 11
Fed up
Biggest mistake ever swapped from normal sky broadband to bt infinity , nothing but problems constantly cutting out not great when your in the middle of doing something ..never had any issues with sky broadband just wanted something faster wish i hadnt know .All tests run and reckon there is no fault .when its cutting out about 5 times in s hour id say there is a fault .Any one else with this problem
10 REPLIES 10
Message 2 of 11
Re: Fed up
if  you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
The stats for the Home Hub 6 can be found on the Information page from http://192.168.1.254 then Advanced Settings -> Technical Log.
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
Can you post back the results of this checker editing out your phone number
http://www.dslchecker.bt.com
Message 3 of 11
Re: Fed up
Have you tried the quiet line test dial 17070 option 2 you should hear no noise if you can hear noise then it needs reporting to BT faults on 151 with no mention of broadband in the call
Message 4 of 11
Re: Fed up
Thank you john ill try that .honestly think this is just down to bt , this problem is at my mums but same issues with my own
Message 5 of 11
Re: Fed up
Also im not sure what hub it is how do i tell
Message 6 of 11
Re: Fed up
there is a label on the hub
Message 7 of 11
Re: Fed up
can you also please post the other information I have asked for
are you using a wired or wireless connection when you get the connection drops
Message 8 of 11
Re: Fed up
Hi john my son is using wired to his xbox .basically the hub lights go orange and drops out .Not sure how to get the information up .
Message 9 of 11
Re: Fed up
just copy and paste the pages asked for in your reply
Message 10 of 11
Re: Fed up
Sorry have been in hospital .it is still having the same problem .Product name:
BT Hub 6A
Serial number:
+084316+NQ71105790
Firmware version:
SG4B1000B316
Firmware updated:
03-Aug-2017
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 18 Minutes 54 Seconds
Data rate:
10.00 Mbps / 55.00 Mbps
Maximum data rate:
22281 / 70820
Noise margin:
13.9 dB / 10.1 dB
Line attenuation:
16.1 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
14 MB Uploaded / 35 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-P8XP
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-P8XP
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A0:8E:78:14:BC:B1
Software variant:
Boot loader:
7.33.1
