Message 11 of 15
Re: Fibre 1 (FTTC) - Telephone problem?
I agree with @licquorice  your connection looks good - enjoy the faster speed
Message 12 of 15
Thank you both!
One thing I noticed:  In the technical log it says "BT Wi-fi: Activated".
Again? I had opted out and this was confirmed via Home>Status page:
"BT Wi-fi status: Not active"
Which one is right?
Message 13 of 15
The upgrade and new hub has probably re-activated btwifi. Wait a few days then opt out again. If still says you are opted out then opt in wait 24hrs then opt out and that should fix it
Message 14 of 15
You mean it could have re-activated BT Wi-fi, even though I'm still opted out?
And even though wireless is turned off:
Or could it be that it did opt me in again without asking me?
Message 15 of 15
Turning the hub wifi off is nothing to do with btwifi.  The upgrade could more than likely opted you back in to btwifi
