Message 1 of 4
Fibre 150 slow wifi
I've just moved to BT after being with talktalk.
My WiFi devices speed with talktalk was always in the 40-50Mbps on 2.4Ghz and 5Ghz, and I was on their 67Mbps copper line.
Got new fibre line installed with smart hub 2 and my WiFi speed on 2.4Ghz devices is really slow. Get about 10-20Mbps. 5Ghz devices are showing 100-140Mbps which is great.
Is the 2.4Ghz on the smart hub 2 like this. My son's Xbox always ends up on the 2.4 and it is unplayable. It was always ok with talktalk.
Ideally I'd like to split the ssids but I know that can't be done. Any help appreciated
3 REPLIES 3
Message 2 of 4
Re: Fibre 150 slow wifi
did you turn off smart set up in hub manager
try changing the wifi channels from auto to a selected channel probably using a wifi analyser on phone to see which channels would be best
Message 3 of 4
Is the smart setup you refer to in the channel selection. I have switched it off smart to different channels using analiti as a guide to which channels are less congested.
5Ghz is great but 2.4 is rubbish
Message 4 of 4
I have found the smart setup and turned it off.
I use a mobile and smart setup isnt listed when you go to hub settings. I used a laptop to turn it off. I will see how it goes
