Message 1 of 5
Fibre 500 - Speed
Hi,
I've recently signed up for the BT Fibre 500 and all is working pretty much fine.
My only question to whoever is on the same contract: did you ever actually get even close to 500?
My max has been around 350, but usually I am not moving from the 280/300. Is this normal?
My setup is: Smarthub2 and BT whole home discs.
Thanks!
4 REPLIES 4
Message 2 of 5
Re: Fibre 500 - Speed
When I was on fibre 500 my download was about 506 and upload 80.
Are your speeds Wi-fi or with a cable plugged into the back of the smart hub?
If it’s over Wi-fi try a cable from the smart hub as a test to see what you get.
Message 3 of 5
I have tested it on the ethernet and I get about 500/506 as speed which is great.
I am left now to sort out my wifi speed, that is averaging at 300mb.
Does anyone have any suggestion?
Thanks!
Message 4 of 5
That’s probably not too bad to be honest when taking into account device limitations, interference etc. You might get a little more with a mesh network if you’re OK with the cost.
Message 5 of 5
Thanks!
