Message 1 of 4
Fibre 900 Speed goes higher than 1gbit
My speed at times goes well above 1Gbps, I’m not complaining but I was under the impression that the 900Mbps was a maximum speed. Is this normal?  
3 REPLIES 3
Message 2 of 4
Re: Fibre 900 Speed goes higher than 1gbit
Nah, it's just fast.com acting like an elastic band, use speedtest.net for a more accurate test.
Cheers
Ted
Message 3 of 4
@Themurn
Don't build your hopes up.😂
As quoted that particular speed tester is about as reliable as a bus arriving on time.🤣
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 4 of 4
I knew it looked suspect, I am very happy with the speeds though . A solid 850 - 950 on wired and 650+ on Wi-fi.
