Hi
I upgraded from Fibre 250 to Fibre 900 and the upgrade went through overnight.
I am getting increased Upload speeds at a consistent 110mbps which is great
However the download speed seems to be slower than under my previous package of Fibre 250 (or 300, can't remember what it was called but the previous fastest speed). The speeds upload speeds I am getting now (to my wifi device vary between 140 and 200 using the My BT app and Speedtest. I appreciate that wifi can run slower than the wired connection. I can't test a wired connection as I don't have a device with an ethernet port
In addition, the My BT app on the phone - when running a speed test - used to show "Speed to the Hub" and previously showed a consistent 292mbps to the hub. But at the moment it's only showing the "Hub to device" speeds so I can't tell if the 900mbps speed is reaching the house.
I have a Smart Hub 2. Additionally the "track my order" in my account is confusing as it says complete but not all the stages are ticked in green.
My question is whether I should expect an increase in download speed to come later once an additional step is completed somewhere on the backend? Or something else?
many thanks in advance
Col.
Solved! Go to Solution.
The speed to a WiFi device is always going to vary and will always be lower than the 900Mbps you're paying for.
Unfortunately the only way you're going to be able to see if the speed has increased (I have a feeling it has) is to test via Ethernet on a Gigabit capable Network card.
Do you know what chip your WiFi devices have? or what WiFi devices they are and I can find out. Also are you using 2.4GHz or 5GHz?
Same here. Upload has increased but not download.
OK I just took the phone I was using to do the tests (ipnone 11 802.11ax) and stood right next to the router and got a download speed of 400mbps so I'm reasonably happy that I'm getting a fast enough speed coming into the house
many thanks for your help!
I've recently upgraded to 900 but getting mad 180down.
As consumers it's not our role to understand network cards, GHz, 2.4, etc.
I take the car to the expert.
Waited a week. Nothing. I understand it's unusual circumstances.
@Kilgeever53wrote:I've recently upgraded to 900 but getting mad 180down.
It is unreasonable to expect BT to know every bit of equipment you have at home. There are so many variables but the vast majority are satisfied.
@colin_nealwrote:OK I just took the phone I was using to do the tests (ipnone 11 802.11ax) and stood right next to the router and got a download speed of 400mbps so I'm reasonably happy that I'm getting a fast enough speed coming into the house
Just an idea as I encountered something similar a good while back although not with the supersonic connection you are enjoying. Would your computer happen to be either a Dell or an HP? I ask because they usually come with added software that sometimes affects "speeds". Further, have you checked the user guide to ascertain whether your wireless card can support these sort of speeds?
(We're off shopping now, so perhaps one of the forum's experts may offer some better technical advice)
Hi everyone - thanks for the help with this. I managed to plug in an Ethernet Cable into a desktop PC and I am getting around 850 to 900 mbps now
I guess it's just the my bt app that doesnt' show the "speed to the hub" and only "speed to the device" after the upgrade that was throwing me
All good here now. thanks again
Col.
Mine is still the same, download speed has actually reduced from what we were on before
