Message 11 of 15
Re: Fibre 900 very slow
Thanks for your responses guys, appreciate it.
The wi-fi card is nothing special, it is a bolt on to the motherboard so likely a cheap one not very good one. I could put my hand it my pocket and get a decent one but in truth using an ethernet cable is not that much of an issue to be honest.
Message 12 of 15
Without knowing what wireless card you presently have it's impossible to say if you need areplacement.
It is also worth noting the superhub is not a Wi-Fi 6 device.
A wired connection is always better than wireless.
Anonymous
Not applicable
Message 13 of 15
Hello again @honoursword,
I 100% agree with @pippincp on this 👍!
Kind regards,
DanTMan64
Sent from my PC
__________________________________________________________
Products with BT: BT Fibre 2 (Unlimited) with Landline
Router: BT SmartHub 2 (Will be changing to a third-party one soon)
Router sync speeds from the local Cabinet to my router:
Download - 66.698mbps
Upload - 20mbps
If you like my post or if it helped you, please thumbs up & click on Kudos button.jpg button. If your problem is solved by my post please click MaAS button.jpg button ‌‌.
Message 14 of 15
Funny thing is after I disconnected the ethernet cable and went back to wi-fi it jumped to 200mbs. Odd.
Thank you both, I'll stick to my trusty ethernet cable then. Cheers
Anonymous
Not applicable
Message 15 of 15
Hello @honoursword,
No worries 😜 happy to help you.
Kind regards,
DanTMan64
Upload - 20mbps
If you like my post or if it helped you, please thumbs up & click on Kudos button.jpgbutton. If your problem is solved by my post please click MaAS button.jpg button 🤗.
