Message 11 of 14
Re: Fibre Broadband availability (or lack there of)
if your home had FTTP there should be a white openreach box conencted to the phone line
Message 12 of 14
please edit out your address this is a public forum viewable worldwide
Message 13 of 14
fibre ont.jpgyou appear to have a copper line
Message 14 of 14
It looks like you're in a FTTP enabled street. Have you checked more than one door number using the ADSL checker?  Try a couple of them and if they all say they have WBC FTTP available now then definitely raise the form to Openreach and have them check their records as it could be a database error.
You will find that you will likely get an automated answer from Openreach the first 2 or 3 times you raise the form.  My advice is to keep raising it each time you're given the stock response that is sent.  Eventually it does get to a real person to look at it.
