TheHorseman
Message 51 of 101
Re: Are openreach telling me porkies
I would have expected it to be on the checker. My cabs go live date was March 31st 2011 and it was showing on the BT checker in November 2010, maybe a little before.
Keith_Beddoe
Message 52 of 101
Moved:
Re: Open reach says Yes, Infinity says No
Bodel32
Message 53 of 101
Fibre enabled cabinet 100m away but yet no fibre?
Hi all,
we've had a fibre enabled cabinet less than 100m from our house for some months but yet BT checker says our house is not scheduled for fibre.
any idea why we'd not be able to obtain fibre but yet the house over the road is??
thanks!
Ectophile
Distinguished Guru
Message 54 of 101
Re: Fibre enabled cabinet 100m away but yet no fibre?
Perhaps because you are connected to a different cabinet?
RichRolls
Message 55 of 101
Strange as it may seem, it probably means you are not connected to that cabinet, but perhaps to another one that has not yet been enabled, or else you are connected straight to the exchange.
I assume you have a BT line, so the BT checker will be the most accurate.
Rich
If you found this information helpful, please click the star to the left of this post. If the reply answers your question then please mark as ’Mark as Accepted Solution’
Sumrandom123
Message 56 of 101
Which cabinet am I on?
Hi guys, new to the forum.
I'm just wondering which cabinet am I on? My postcode is cf41 7qd and my local exchange is tonypandy which is due to be enabled for infinity on December 31st. Just wondering because there are 2 cabinets of which I can find that are about the same distance from my house so I'm assuming I must be using one of them. They are p5 and p6 I think but p6 has a nice new upgraded fibre cabinet and p5 just the old one. Really hoping I'm on p6 but not getting my hopes up. So any help would be grateful. Thanks guys
plainview
Recognised Expert
Message 57 of 101
Re: Which cabinet am I on?
Go to this URL: https://www.btwholesale.com/pages/static/Community/Broadband_Community/Coverage/ADSL_Availibility_Ch...#
Enter your phone number and hope it says FTTC is coming your way.
FTTC_UT
Message 58 of 101
Is it possible to move my lines cabinet to Infinity enabled nearby?
Hi All
I have recently moved into a new development to which I found out Fibre wasn’t available to my cabinet.
After some research I realised my neighbours on the opposite side of the road (which aren’t new builds) have access to Fibre. I wanted to know if BTOpenreach can move my line to a cabinet that has fibre enabled.
Due to business justifications I’m sure BT will ever enable my cabinet, as my current cabinet doesn’t serve many houses for them to recoup their money back. I’m currently stuck on a 1MB or less connection and desperately need a faster line as I do a lot of work from home which is bandwidth intensive.
All help will be appreciated.
Regards
RichRolls
Message 59 of 101
I am sorry to tell you that these dates often slip.  Look around the forum and you'll find plenty.
I would think that after Christmas, the date will slip a quarter to 31/3/13, and then probably to 30/6/13 near the end of March.
Ours finally went in about 7 months after vthe initial date quoted.
I hope I am wrong, and that you do get it by 31/12.
Rich
dylanere
Message 60 of 101
Upset :( Date Changed
On the checker it used to say dec31st 12, now it says, mar31st 13 😞
