kornell
Message 1 of 6
Fibre issues.
Hi,
I am 613m from my PCP and my router is synced at around 24Mbps/4Mbps upload. My lowest assured speeds according to the BT retail website is 26Mb and my estimate is around 30-40. I'm on Employee Infinity package and using latest BT Smarthub.
I suspect my line might be alu, which could explain massive drop of speeds, as I am not that far from the PCP to have speeds degraded. And as you can see my capacity is just short off 28Mbps.
Data rate:
4.08 Mbps / 25.04 Mbps
Maximum data rate:
4158 / 27634
Noise margin:
6.3 dB / 5.1 dB
Line attenuation:
24.8 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
5 REPLIES 5
imjolly
Message 2 of 6
Re: Fibre issues.
are the stats from using the test socket with a filter/  if not can you use test socket to see if that helps
if you have aluminium cable as part of your conenction that would reduce speed and checker estimate would not take that into account
kornell
Message 3 of 6
Re: Fibre issues.
Yes, they are from the back plate, with a filter. I'm using an SSFP too.
imjolly
Message 4 of 6
Re: Fibre issues.
you are only marginally below 26mb connection - what was the minimum guaranteed speed quoted in BT's original letter?
kornell
Message 5 of 6
Re: Fibre issues.
25Mbps
imjolly
Message 6 of 6
Re: Fibre issues.
and that is your current speed from your router  you can try getting an engineer visit see speed can be improved
