Message 1 of 7
Fibre with BT Halo 3+ Plus hybrid connect yet my internet is shocking, lagging and Dropping
Fibre with BT Halo 3+ Plus hybrid connect yet my internet is shocking, lagging and Dropping in and out constantly yet I’m paying a shocking £65.99 per month 🥺
6 REPLIES 6
Message 2 of 7
Re: Fibre with BT Halo 3+ Plus hybrid connect yet my internet is shocking, lagging and Dropping
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal - will not work if you have digital voice
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
have you turned of smart setup
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 7
I would have thought with the information that the OP had provided it's full fibre. If that's the case then it's more likely to be a WiFi issue.
Message 4 of 7
@Checked2013
if OP posts more information we will know what the problem actually happens to be rather than just guess
Message 5 of 7
Not really, Halo 3+ exists on all packages including standard BB and FTTC
Message 6 of 7
@imjolly It might be a good idea to change your copy and paste answer as it does assume that someone doesn't have full fibre.
Message 7 of 7
@Checked2013
thank you for your suggestion but will stay with my macro as majority of customer do not have FTTP
