Message 1 of 7
Fibre900 Speeds with Ubiquiti Dream Machine
Hi, is anyone running Fibre900 with a Ubiquiti Dream Machine and if so what download speeds are you seeing with intrusion detection /deep packet inspection both turned off and a cable connection?
6 REPLIES 6
Message 2 of 7
Re: Fibre900 Speeds with Ubiquiti Dream Machine
I have a UDM and have just ordered Fibre900 - will keep you posted.
Message 3 of 7
Hi, I have that exact set up.  Before and after the UDM, I'm hitting the same speeds c.800 - 840Mbps.
Switching intrusion detection on made no difference - I think the UDM is rated at 850Mbps for dpi & int. det.
Message 4 of 7
Thanks @jchasty , do you know if those are the same speeds to your ONT or a limit of the UDM?
On paper I think I read the UDM is ~850 with intrusion detection enabled.
Are you happy with the UDM in general? I’ve just swapped over from a SmartHub2 and so far it’s been a pretty good experience.
Message 5 of 7
Yes, very happy.  In fact, I went full on with Ubiquiti APs and PoE switches - all brilliant!
Message 6 of 7
That’s great news @jchasty
I’m trying to avoid the temptation of adding APs myself just now as I’ve an Orbi mesh in AP mode.
I’m sure I’ll give in soon enough though.
Message 7 of 7
Yeah, I went a bit mad and added 5 switches and 5 APs....    🤣
