Gigabit
Message 21 of 28
Re: Filters slowing Broadband speed - help suggestions
By the way, if your exchange ever gets 21CN. then you could get approximately 20Mb.
Guru
Message 22 of 28
Nice one Don .... why I gave you the gold ..... but you know that 😉
Hope you enjoyed the sabbatical,  and rest.
A good and valuable lesson for the OP
d_cregg
Message 23 of 28
I do wonder about the cable being the problem and not the hub too now, John46!
I did suggest that in the beginning when on the phone with technical support at BT, but went through a whole bunch of tests on the phone with BT and they were the ones who suggested a new hub.
D Cregg.
@john46 wrote:
must admit I don't understand that one
just looked back to the original post  and the hub was changed becuase of ow speed problems  I wonder if the cable was the problem all along
Guru
Message 24 of 28
In that case, well done you also.
BT staff do make assumptions based on sheer numbers of queries ... and what "seems to fix the problem" sometimes.
Often, without thinking about the obvious.
Message 25 of 28
thanks RogerB
I am not 'back' but like you popping in and out and making a few posts if I think I can help
Message 26 of 28
It could have been a telephone cable, and not a modem cable. The pinouts are often different, but there would have possibly been a bit of leakage between the wrong and right pairs, for the home hub to see a signal.
It quite easy to get mixed up, if you have a box of cables with a BT plug one end, and an RJ11 the other.
Guru
Message 27 of 28
Indeed Keith ...
One has to assume square pin into round hole syndrome ..... doesn't apply.   😉
(I could knit a jumper with failed cables I possess, from over the years.)
Message 28 of 28
I have book marked  this post incase it ever occurs again well done IMJ  😉
