Message 1 of 7
Finally worked out why I'm being DC'ed - please help!
After months of being randomly DC'ed I have finally worked out the cause. Basically any time my land line receives or makes a call, I get disconnected. The DC lasts only a few seconds and the connection is restored very quickly, but it is enough to ruin attempts at online gaming for me.
I have tried replacing the microfilters, but to no avail. What's next?
6 REPLIES 6
Message 2 of 7
Re: Finally worked out why I'm being DC'ed - please help!
Connect to the test socket to eliminate any internal wiring problem.
Testing from "test" socket
Message 3 of 7
That link doesn't work, possibly because I am connected at work right now. Can you elaborate what I need to do? Thanks
Message 4 of 7
There is nothing you can do anyway, until you get home. There are also quite a few other ADSL help pages on that website, as its quite a common problem.
If you post later on, there is usually someone available to help you.
Message 5 of 7
I discovered my Sky box in the other room did not have a microfilter. The thing at the end of its phone cable that I thought was a microfilter was in fact just a splitter. The problem is now fixed after adding a filter there.
Out of interest, if it was the Sky Box that was the cause why was it calls to/from the landline phone (which had a filter and was in a different socket) that was triggering the disconnect. Just curious!
Message 6 of 7
sky boxes are a known source of interference as the regularly phone home to sky
Message 7 of 7
The Sky box "splitter" is the cause of many problems, that is why I mention it on my website, and include a diagram showing how it should be connected.
