Message 11 of 53
Re: Browser connection problems
@FloFosterJenkins wrote:
Can someone please rename the whole thread? It's not just Firefox:
Had this problem Christmas 2012. I was furious.
There's a command "flush DNS" which you can find on Google. Ooops your browser doesn't work! If you do find it, t's worth a try.
Oddly, the only way I could fix it was to plug in a USB wireless adaptor, using that for wireless and disabling the PC's wireless. I don't know why, but somehow it changed the ip address.
The problem went away after a week, after rechecking the PC's own wireless connection.
Message 12 of 53
Thanks Ribblelancs. I'll look it up. Meanwhile:
BTcare keeps saying:
Secure Connection Failed
An error occurred during a connection to community.bt.com. SSL received a record with an incorrect Message Authentication Code. (Error code: ssl_error_bad_mac_read)
    The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
    Please contact the web site owners to inform them of this problem.
IE says:
Firefox says:
Message 13 of 53
Ribblelancs, this is a desktop connected by ethernet cable to the Hub, so it's not a wireless issue.
Message 14 of 53
Sorry if it's a stupid question.
Have you deleted your shortcut to BT Community, and created a new one?
Out of habit, I don't have one. Only a shortcut to bt.com.
Message 15 of 53
No, but I've been accessing BTCare via Google as well. It makes no difference. Other sites show the same symptoms. Flushed the dns cache.
Next step is to plug a laptop into the ethernet port of the Hub and see what happens.
Message 16 of 53
Not stupid! But I don't think that's relevant. I've tried accessing via Google search. Same symptoms, and on many diferent sites, like that Pi one above.
Flushed DNS.
Next step is to connect a laptop to the Hub by ethernet. That should determine if the fault is in the desktop or the Hub.
Message 17 of 53
Hmm... all working normally right now. Of its own accord. All I did was nip out to the local shops for some fresh air to cool down the frustration that this has caused.
licquorice
Message 18 of 53
I nipped round and fixed it while you were out!! Smiley Happy
Message 19 of 53
Much obliged Smiley Happy
Message 20 of 53
Can you return please - it's happening again. Exactly the same symptoms Smiley Mad
