jaydog69
Message 1 of 2
Firewall?
I'm actually not sure if my connection is behind a reliable firewall or not?!
I have a Netgear DG834G which I presumed had a built in firewall. I have Windows Firewall within Win 7 enabled, but is it a proper one?
From tomorrow I'll be with BT using a Home Hub 3. Do I need to install a firewall??
Sorry, bit clueless when it comes to this. Cheers.
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: Firewall?
Hi.
The DG834G does have an inbuilt firewall just like the HH3, but for safety you should use a software firewall as well.
Windows inbuilt firewall or most other software firewalls are good enough, or maybe try a security suite, like BT's Net protect Plus, Microsoft security essentials. Thats just 2, but thewre are many out there, some free, some paid for.
toekneem
(EASBF)
