Hi All,
I am just curious - my Smarthub has not had a firmware update since July 2018 ...does that sound right?
I just assumed that updates would be more frequent than just once a year?!
Apologies if this is an obvious question ….but any answers would be much appreciated!
Hub firmware updates are automatic and will happen as long as you leave your hub connected 24/7. There is no manual way to update the firmware
Thanks for the reply.....I appreciate that it is automatic, but could the system not be working correctly if there has mot been an update in all but a year?
Nick
If you post what hub you have and note the firmware version that’s currently installed hopefully someone on here will be able to confirm whether you have the latest/current version.
Brilliant...thank you …, I have a ;
Smarthub 6 and the firmware version is v0.09.06.05093-BT
The last update is logged as: Fri Jul 20 10:55:41 2018
Does that sound about right??
Any help much appreciated.
Mine is smart hub-6 firmware is SG4B1000E016 date June2019.
hope this helps.
There are 2 versions of the hh6 hence why the firmware is totally different
