davedrizen
Message 81 of 133
Re: Firmware Update Today
May be some one from BT could explain what this bug  cause to happen. From evidence so far there is little problem with people that have the new software.
As a major partner of youview I find it Very strange that BT was not able to test this software at the same time it was being Trialed and tested by youview, bearing in mind the fact  that the retail box has the same capability to use the BT vision app and unlike the talktalk ( which has extra service ) the BT box is a bog standard Humax youview box.
I know for fact that Youview  went to great Lengths that all types of users trialed the new software before roll out therefore it hard to believe that a major partner would be left out.
To me and probably many other on this forum, this just seems like a excuse, to save face because the roll out is taking longer than expected
SamdyGray
Message 82 of 133
Firmware is the same across all providers, yes? The only BT part of the box is the Vision player.
Why bugs in BT Vision player SOFTware should prevent a FIRMware rollout is beyond me. Bugs in Vision player do (should) not affect the overall operation of the box.
BT should allow the update and then concentrate on fixing their own buggy software.
walkerx
Recognised Expert
Message 83 of 133
if bt trying blocking my update I won't be happy, especially as I've purchased my own retail box and won't be using the bt app on it
TheBlade
Message 84 of 133
Don't worry, you won't have a problem if it is a retail box, even if you are connected to BT Broadband/Infinity.
As far as we can tell it is purely the serial number of the Humax boxes which BT deliver are blocked.
walkerx
Recognised Expert
Message 85 of 133
Good
cactusbob
Message 86 of 133
I suspect all updates have now been stopped. Have you tried a manual update?
walkerx
Recognised Expert
Message 87 of 133
ok - installed my new youview box tonight and it updated automatically, so now on the latest version
just now got to setup the bt vision box in another room until the contract expires
or will just be able to use the bt app in interim
cactusbob
Message 88 of 133
Excellent news, does the BT Vision app work?
walkerx
Recognised Expert
Message 89 of 133
not tested yet, but now tv and iPlayer both fine. Just concerned if I run the bt app if they then try charging for it or billing me £200 for powering off my bt vision box and probably not switching it back on. Nothing in contract to say you can't keep powered off, only it must stay connected to network. Which it is.
cactusbob
Message 90 of 133
This confirms nicely that retail boxes are still being updated. Out of interest do you have a BT icon appearing on the initial menu at the bottom?
