I think something might be wrong with my router, the firmware has never changed.
It has Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 11/07/15
Is this the latest version for type A HH5?
Solved! Go to Solution.
No it isn't - but there's nothing you can do about it. For what it's worth, I'm on the same version as you.
i,m also on the same firmware and it seems to work fine 🙂
