Cbcarolyn
Message 11 of 16
Re: Firmware update 4.7.5.1.83.8.236.1.2 rebooting constantly
so do you think this is this a hub issue and is it fixable anyone know, or is it only solvable with a new box?
Or can it actually be a line issue?
don;t want to sign up for another year and find out that it wasn't the box 😞
Webby
Message 12 of 16
If it's a line issue it would be the same with whichever supplier you went with anyway.
alanfleming100
Message 13 of 16
WARNING - BT Home Hub 5 "Forced Firmware Upgrade" July 2017 is NOT seamless / invisible.
You MUST do a full BT Home Hub 5 disconnect power off / on  reset AFTER the forced firmware upgrade.  Re-start button on top of the hub is NOT good enough.
The problems I had/still have have after my forced BT Home Hub 5 forced firmware upgrade are contained in another new thread.
Regards,
Alan
York   UK
Cbcarolyn
Message 14 of 16
We switched it off last night and powered up this morning, still no better, maybe a factory reset again?
Cbcarolyn
Message 15 of 16
don't want to tempt fate - but following a switch off, I have factory reset again, and it seems to be stable.
Cbcarolyn
Message 16 of 16
Well other half switched off power in error, and then it took several rebooting attempts befoe it was stable again.  Just seems too much of a coincidence that it has gone wrong following a firmware update.
