Message 1 of 3
Firmware upgrade ?? should this have happened ...help with understanding.
Wondered if someone could explain this below .... wifi dropped today, came back - had a look in logs and found several Firmware messages amongst other stuff. Question is :   why the "!" after the build version thats looks to have been synched & doesnt firmware normally upgrade in the scheduled hours that have been set - in my case : 0200: 0600 ?  Finally what is the significance of the "HTTP -start.." entry.
Cheers.
01.04.2020 15:25:45 OWL-Sync config success
01.04.2020 15:25:45 Firmware upgrade - FW SYNC compare WHWv1.02.11build02 WHWv1.02.11build02!
01.04.2020 15:25:31 The Firmware Upgrade Auto Check will be triggered at this month Apr. 4,18 04:30:00 and the next month May, 2,16,30 04:30:00.
01.04.2020 15:25:31 Current firmware version is v1.02.11 build02 and boot flag is 1.
01.04.2020 15:25:30 IF[2.4G]:STA(A4:FC:77:8A:1C:EB) had deauthenticated,reason is 3
01.04.2020 15:25:29 HTTP-start ..
2 REPLIES 2
Message 2 of 3
Re: Firmware upgrade ?? should this have happened ...help with understanding.
Hi,
Hopefully I can help!
- It's just part of the log entry, it's not actually in the build number.
- Yes the automatic check/upgrade is during that window but all secondary discs also check they have the same firmware as the primary disc when they connect at a management level - this could be anytime they reboot, reconnect Wi-Fi or restart any internal services. This is to make sure all discs always have the same firmware.
- It's logged when the HTTP web server starts. It may be that your disc restarted services (to automatically fix a fault) which resulted in the new firmware sync event. It shouldn't be anything to worry about unless you are having other issues.
Stay safe & keep well,
Dan-O
Message 3 of 3
Thanks Dan-O,
appreciated. I've popped a couple of issues /observations on this week,don't know if linked   - grateful for any insights you may have these. Cheers.
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Suspicious-Router-Network-activity-Man-in-the-M...
https://community.bt.com/t5/BT-Devices/Network-Map-question-connected-devices-Advanced-settings/m-p/...
